hi everyone, need some help on this one
i've installed autocad 2013 on my pc 64bit, intel i3 processor with 6GB RAM. yet after installation and run it for the first time, it stays for 3-5 secs then it closes..now i've uninstalled it, wiped traces of cad in the system and registry, installed again, run then it just flashes..
what might be the problem here?
thanks!
turn off/disable your antivirus software and start AutoCAD by right-clicking and use option "start as administrator" ... does the same happen?
Do you see the full AutoCAD these 3-5 seconds or is it the splash screen for some seconds before it's closing?
Does it report any exceptions?
- alfred -
>> it just flashes
It just flashes means now the AutoCAD or the splash screen of AutoCAD (the startup-image)?
Have you tried to start as admin?
And another question: were you asked already for the activation of the license?
- alfred -
>> just the splash screen only
Look to >>>that link<<< and try follow that steps.
Good luck, - alfred -
Refer the below Autodesk solutions for previous versions, I am not sure that still apply to new one
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14908069&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15176093&linkID=9240617
