AutoCAD 2013/2014/2015
Active Contributor
dlipscombe
Message 11 of 40 (881 Views)
Re: Autocad 2013 Paperspace viewports
04-04-2012 08:25 AM in reply to: luconceicao
no its all files, its not the commands thats causing the problem, its something to do with zooming in and out repeatedly that causes it, dont need to be in a command for it to happen, bigger the file size, the more likely it is to happen. seems its been a problem with the 2012 edition also, but i never had an issue with it til now. To get it to react quick just zoom in and out to extreme until jumps out of the viewport.
Product Support
luconceicao
Message 12 of 40 (879 Views)
04-04-2012 08:36 AM in reply to: dlipscombe
What is the operating system, graphics card and driver that you have?
You can see this information easily in the tune log with the 3DCONFIG command.
Active Contributor
dlipscombe
Message 13 of 40 (875 Views)
04-04-2012 08:45 AM in reply to: dlipscombe
Windows 7 Pro 64 Bit
Processor 3.3Ghz
RAM 4071Mb
NVIDIA GeForce 210
Driver 8.17.0012.9610
Product Support
luconceicao
Message 14 of 40 (872 Views)
04-04-2012 09:01 AM in reply to: dlipscombe
GeForce graphics cards are not especially designed for CAD. Your card is more appropriate for watching videos:
http://uk.geforce.com/hardware
Do you happen to have another machine that you can test this behavior again, preferably one that has a supported/certified card and driver?
Please see the list here:
http://www.autodesk.com/autocad-graphicscard
I would be interested to know if anyoe else can reproduce the issue with the viewport as I currently can't.
One more thing you could check is to see if the issue persists in Windows diagnostic mode:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404186&linkID=9240617
Does it make any difference?
Cheers,
Luciane
Active Contributor
dlipscombe
Message 15 of 40 (853 Views)
04-05-2012 12:10 AM in reply to: dlipscombe
There was an earlier post from someone having the same problem in 2012, but no solution to it.
Product Support
luconceicao
Message 16 of 40 (844 Views)
04-05-2012 06:49 AM in reply to: dlipscombe
Do you get anything different in Windows diagnostic mode?
Luciane
Active Contributor
dlipscombe
Message 17 of 40 (842 Views)
04-05-2012 06:52 AM in reply to: dlipscombe
Autocad wouldnt start up, i have a stand alone licence so dont know why??
Product Support
luconceicao
Message 18 of 40 (839 Views)
04-05-2012 06:57 AM in reply to: dlipscombe
You have to enable the licensing system:
If these steps don't work for you please let me know.
Active Contributor
dlipscombe
Message 19 of 40 (831 Views)
04-05-2012 07:18 AM in reply to: dlipscombe
same thing, to be honest i have given up on it and just started working with expanded viewport, was either that or go back to 2012, dont feel expanded viewport is ideal given i can have up to 10 to 12 viewports on a sheet, anyway cheers for looking into it.
Product Support
luconceicao
Message 20 of 40 (820 Views)
04-05-2012 07:51 AM in reply to: dlipscombe
OK, I'll have a look and let you know.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
