Using 2014 AutoCad educational version. Unable to set the MBUTTONPAN on the mouse. Rechecked mouse settings and its says 1... Have switched it back and forth from 0 to 1. Pan won't work unless I key in PAN in ribbon/command line, but then need to esc. to continue other commands. Please let me know how to have the PAN command accessible when using mouse. Have used this program for a while and has always worked. Checked the pan in other programs (Sketchup etc.) and works fine. This setting just went inactive about 1 week ago...Please help - Thanks
MBUTTONPAN = 1 Middle button works as PAN
MBUTTONPAN = 0 Middle button brings up Objectsnap menu
Can't have both on at the same time
I use the Objectsnp menu and just click on the pan button to do my pans
Ron
