AutoCAD 2013/2014/2015
Member
0 Kudos
Post 1 of 4
Autocad 2013 hatch
5976 Views, 3 Replies
09-11-2012 12:48 AM
I recently upgraded from Autocad 2011 to Autocad 2013. When editing hatch in 2011 I used to be able to single click the hatch pattern, and then use one of the many grips to edit it, but now, when single clicking the hatch pattern in Autocad 2013, only one grip appears in the centre, in the form of a blue dot.
How do I set my Autocad 2013 to behave as it did in Autocad 2011?
Thanks in advance
Turn your hatch to non-associative (either in properties - or a tick box when you create the hatch in the dialogue). But it is probably better to leave it as associative and just select the object that you have hatched and edit that (the hatch will change with it).
Distinguished Mentor
89 Kudos
Post 2 of 4
Re: Autocad 2013 hatch
09-11-2012 01:33 AM in reply to: k3rnal
Regards Steven Gray
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
Member
0 Kudos
Post 3 of 4
09-11-2012 01:47 AM in reply to: steven-g
Thanks for your reply.
Unfortunately I do have my hatch selection set to non-associative, but still only get a "blue dot" grip in the centre of the hatch pattern, instead of the usual boundary grips?
Member
0 Kudos
Post 4 of 4
09-11-2012 02:06 AM in reply to: k3rnal
Sorry, you were rite! :smileyhappy:
I don't know what it was, but when I restarted my Autocad, it worked perfectly fine when associative was un-checked.
Thanks a mil!!
