My company has recently updated all users machines with AutoCAD 2013 or 2014. I run 2013.
Personally I prefer to use the customised version of the classic workspace as I do not like the full ribbon interface as it is clunky, slow and the toolbars take up too much space. (I use keyboard shortcuts anyway). However every time I go into CAD it always defaults to the ribbon mode despite me setting the Classic workspace and the automatic save changes before shut down of a previous session. Is there a system variable that I have to use i.e. 0 or 1 to set Classsic to default
Also I have had numerous crashes with this software, is this common? I am not at present running the recommended requirements of 4GB of ram as I am on a 32 bit system so suspect its something to do with that. Service packs are up to date.
When I do any selection type work I have lots of little crosshairs appearing which only go way after I hit the cancel command - again is there system variable that switches them off ( screenshot attached)
Hello
Assuming you have the SP 2 on your ACAD 2013 and the SP 1 on your ACAD 2014 !
Please can you run a little bit with Hardware Graphic Acceleration DISABLED to see if you crash less !?
Which graphic card on your PCs ?
Which Windows exactly : Win XP Pro, Win Seven , Win 8.0, Win 8.1 ??
Patrice BRAUD
Re: Workspace
Do you have Automatic workspace saving turned On or OFF? If OFF (recommened) are you manually saving before closing or switching to a different workspace/profile? Do you perhaps have an existing workspace switch in your AutoCAD shortcut that's causing AutoCAD to start in a Ribbon based workspace?
Those crosses look like blips. Type .BLIPMODE (with a period in front) and set it to off.
Ok .blipmode did the trick for that issue.
Classic mode automatic saves are selected but maybe there is a something in the boot up routine which overides it
Have been running with Hardware Accelearation off since it having it installed
We run XP Pro
Hopefully though they are rolling out Win 7 soon and I have requested an upgrade to 64 bit since I have 8GB of ram - but cannot use all of it!
kentr8 wrote:
blips are still around? who knew
Actually they were removed (technically not removed, only undefined) in AutoCAD2012. Since the OP is using 2013, someone/something either redefined BLIPMODE, or it was somehow migrated forward from a previous release.
Hello
You were speaking about >>> Also I have had numerous crashes with this software, is this common ? <<<
And now you say that BLIPMODE is the solution and everything is OK !
BLIPMODE = ON is only a minor graphic problem, does it crash less with BLIPMODE = OFF ??
Patrice BRAUD
