Good morning everyone,
Attached are two image files that show error messages the users in my office get when closing AutoCAD. Usually these are 2 of the 3 error messages, howerver, message #1 only flashes on the screen for a split second before going away. Message #1 is the same error message as the two images attached only the file it refers to is aecbaseex.dbx. These messages only started about two weeks ago and it started on one machine and seemed to one by one start to happen to everyone else. The error message don't seem to have any impact on what we are doing as the drawings all work and save as usual. We are all running plain AutoCAD 2013 on Windows 7. I've done some research and have found others with the issue, but to this point no solution. I was hoping some light could be shed on the subject before we start reinstalling. I have tried to do repair installs and that didn't change anything. Any help would be greatly appreciated. Thanks.
Brian
What changed with the one user two-weeks ago? add-on, upgrade, side-grade, removal of 3rd party content, picked up a to-die-for block from the internet, started a new project with a base drawing from another source etc.?
Are you all really using plain AutoCAD? Not Civil3D or source files from Civil 3D?
Using VAULT?
Are you all using Windows Registry Cleaners? Did this one user?
As far as I can tell, nothing has changed. No add-on, no upgrade, no side-grade. The only possibility is it was something we received from another consultant as we work quite often with drawings supplied to us. But there isn't any way to pinpoint what it might have been. So we are just trying to find a solution and move forward with it.
Hi Brian,
It might be the Civil Object Enabler. Have a look at this article:
http://knowledge.autodesk.com/article/Multiple-ARX-errors-when-exiting-AutoCAD
There is also this article that has several suggestions for crashes when closing:
http://knowledge.autodesk.com/article/AutoCAD-crashes-when-you-close-a-drawing-or-exit-the-program
Let us know if these help!
