AutoCAD 2013/2014/2015
Member
0 Kudos
Post 1 of 10
Autocad 2013 Defaults to Paperspace while drawing in Model Space
1020 Views, 9 Replies
03-25-2013 09:04 AM
Greetiings.....We have just loaded AutoCAD 2013 from previously using Version 2012, and I am experiencing a very distubing phenomenon.  While manipulating the commands in any vieport window in Model Space, the program automatically 'jumps' into Paper Space causing an interruption in work-flow, and losing any command which was in progress during the time. For example, if a number of objects were copied with the intention of placing them elsewhere within the same or another paper space window in 'model space' , the program would jump to paper space and the items would be lost, with the necessity of selecting them all over again.  This can happen several times in a row.
Is anyone else having this problem, and is there a 'fix' available?
Thank You
Bobby S.
*Expert Elite*
1,593 Kudos
Post 2 of 10
Re: Autocad 2013 Defaults to Paperspace while drawing in Model Space
03-25-2013 09:07 AM in reply to: robert.sirico
Which command is being referenced in your statement "...number of objects were copied..."?
Is there a command that is active?
Are you using any keyboard combination keys when this occurs?
Are you in VPMAX when this occurs, or are you simply inside a viewport as viewed in paperspace?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
0 Kudos
Post 3 of 10
03-25-2013 09:32 AM in reply to: pendean
Okay........It appears that this can happen during any command, and the procedure would be as follows;
 I'll click on the Model Tab in a Paper Space window while in Layout Mode to open the viewport to draw, move or copy an item. Suddenly, the Model Tab will Switch to 'Paper' and will need to be reset to 'Model' to continue.  No Particular 'combinations' were used other than the standard single keys such as 'co' for copy, 'm' for move, 'l' for line, 'dt' for d-text', etc.
The Paper Space Window could be zoomed- in to a 'maximum size' or the screen could be zoomed-out to show several or all viewports with the same effects.  I find that from time to time, my crosshairs disappear as well.  This had been a troublesome bug in Release 2012, but happens only occasionally in 2013.
Product Support
30 Kudos
Post 4 of 10
03-26-2013 07:14 AM in reply to: robert.sirico
Hi Robert,
Does this issue happen with all the drawings or only some in particular?
Can you reproduce it with a new drawing created without a template?
Have you already installed the service pack 1.1?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20327837&linkID=9240618
What is the graphics card and drivers listed in the tune log? Does it say it's certified?
Enter 3DCOONFIG > View tune log.
Edit: sorry for typo, command is 3DCONFIG > View tune log
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
Autodesk, Inc.
*Expert Elite*
1,593 Kudos
Post 5 of 10
03-26-2013 10:20 AM in reply to: robert.sirico
In additon to any other tips... by chance do you have TASKBAR variable turned on? Turn it off if so and see if your problem goes away.
Member
0 Kudos
Post 6 of 10
03-28-2013 07:09 AM in reply to: pendean
Good Morning Pendean; In regard to your instructions, I turned off 'taskbar', with no change in original problem. I even had a brand-new Mouse installed by our IT Dept. Sadly, by the end of the day I had experienced such a degradation of performance that I received a message ....."orphaned" (I didn't get the reference number) but I believe the entity (a line string) which I was drawing got 'disassociated' with the rest of the drawing, and the drawing would not respond. I rebooted the machine, opened the drawing in Acad 2011 (the last reliable version......which worked perfectly), and did an audit which found 2 errors. I had to finish the rush-job that I was working on in version 2011. I have just opened the same drawing in 2013 and have done an audit. I haven't had the time to operate this drawing yet in 2013, but I will experiment (time permitting). If I get no positive response, I will ask IT to reinstall 2013. Thanks for your concern and assistance..... I will keep you posted. Bob S. This message, including any attachments hereto, may contain privileged or confidential information and is sent solely for the attention and use of the intended addressee(s). If you are not an intended addressee, you may neither use this message nor copy or deliver it to anyone. In such case, you should immediately destroy this message and kindly notify the sender by reply email. Thank you.
Member
0 Kudos
Post 7 of 10
04-09-2013 10:44 AM in reply to: robert.sirico
Autodesk Fabrication CADmep 2013
I am having the same problem. Very frustrating!
What is the solution?
Utilizing NVIDIA Quadro 2000D card
Product Support
30 Kudos
Post 8 of 10
04-16-2013 09:24 AM in reply to: audiocycle
Do you have any steps to reproduce the issue?
Does it happen with all the drawings?
If you enter 3DCONFIG > View tune Log > does it show the card is certified?
Cheers,
Luciane
Member
0 Kudos
Post 9 of 10
04-17-2013 07:05 AM in reply to: robert.sirico
Just upgraded video card over the weekend from Quadro 2000D to Quadro K5000 & thought it was corrected.....NOT!!!
Just occured when working within a Layout Tab viewport. I was changing from Modelspace to Paperspace. I have (5) Fabrication Spool Sheet Drawings opened & in process when this occured. Now have to completely get out of AutoCAD & start over on the Fabrication Sheets. This is not acceptable & need to find a resolution ASAP.
What do we need to do to provide more information (if required) to help.
Member
0 Kudos
Post 10 of 10
04-24-2013 04:55 AM in reply to: audiocycle
Good Morning......Yes, the problem is a tricky one. I find also that the cross-hairs disappear from time to time, requiring me to exit and restart the program.
All I can suggest is that you use an 'approved' video card. I tried a new 'mouse' which helped somewhat, but in my company the IT Department is responsible for all installations, etc.
I also get 'lock-ups'. The last version which worked flawlessly was release 2011. 2012 had the cross-hair issue and was a real nuisance.
I wish I had an answer for you, my friend. Try different settings in the configuration options, especially regarding video display, and update any patches which might be available.
Good Luck.
RFS
Thank you.
Post to the Community
New Post
