AutoCAD 2013/2014/2015
New Member
0 Kudos
Post 1 of 10
Autocad 2013 commands stopped working
3649 Views, 9 Replies
09-20-2012 10:34 AM
It started with draworder coming back as unknown command. Then I installed service pack 1.1. NOt cui attribute edit and a bunch of other command have completely stopped working. I've not changed anything in cui in weeks. Everything worked fine yesterday. today everything seems to have gone haywaire.
Someone help please...
*Expert Elite*
601 Kudos
Post 2 of 10
Re: Autocad 2013 commands stopped working
09-20-2012 10:45 AM in reply to: amolleken
Sounds like your EXPRESS is not running
Menuload and load the EXPRESS or type in EXPRESSMENU
Product Support
18 Kudos
Post 3 of 10
09-25-2012 09:24 AM in reply to: amolleken
Go into Options, to the Files tab, and look under Support File Search Path. Add the following path if it is not there:
C:\program files\autodesk\autocad 2013\support\en-us
Let me know if this helps.
Bryce Thelin
Product Support
18 Kudos
Post 4 of 10
10-01-2012 09:22 AM in reply to: amolleken
I wanted to follow up with you on this discussion thread. Please let me know if any of the above helped. If it did, please click the "Accept as Solution" button. Thank you!
Bryce Thelin
Active Contributor
0 Kudos
Post 5 of 10
10-15-2012 07:06 PM in reply to: bryce.thelin
Hi Bryce-
Larger issue would be if the program is dumping the file path, why is it doing so?
I've been experiencing many similar issues where all of the 2013 platform products (Autocad, Autocad MEP) randomly dump profiles, won't load lisp, etc. Usually I find that support paths have randomly disappeared from the working support paths table. Sometimes however files won't load even though the support paths indicate they did (sometimes even the APPLOAD dialog indicates they're loaded when they're not... go figure that one). Block libraries go unreferenced, etc.
Our configurations have worked very well (i.e. stable) for 4 years, but with the introduction of 2013, even the 2012 products have the same issues now which really has me puzzled... but since that's the only thing that's changed (adding 2013) to the mix, and the behavior is the same, I have to conclude that they are related or a recent patch to 2012 has introduced the same problems present with 2013.
New Member
0 Kudos
Post 6 of 10
08-27-2013 10:29 AM in reply to: amolleken
I'm a having the exact same issue and my file support path is already set to:
How do we fix this???
*Expert Elite*
601 Kudos
Post 7 of 10
08-27-2013 11:44 AM in reply to: ryan
How many commands not working?
Active Contributor
0 Kudos
Post 8 of 10
08-27-2013 12:10 PM in reply to: ryan
For us, the most effective solution was to completely remove all 2013 Autocad based products from our system - we just had too many problems with it. On most computers we had to remove all Autodesk products, do a complete registry wipe of all Autodesk related entries, and then reinstall 2012. Also, don't install 2012 service pack 2 - seems it's the one that reintroduces the 2013-type problems to 2012. Once we got 2013 completely cleaned out of our computers, 2012 settled back down and we've been working pretty much trouble-free ever since.
You may or may not have the ability to roll back to the previous version like that, but it was the best option for us.
New Member
0 Kudos
Post 9 of 10
08-27-2013 03:55 PM in reply to: Patchy
Layerfreeze, properties, etc. Probably about 25%.
Product Support
18 Kudos
Post 10 of 10
09-09-2013 09:06 AM in reply to: ryan
Try going into Options to the Open and Save tab. Change "Demand load ObjectARX apps" to "Object Detect & Command Invoke."
If this doesn't help, then see if resetting AutoCAD to defaults will. To do this, click  Start > All Programs > Autodesk > AutoCAD 2013 > Reset Settings To Default. It will let you save your current settings first.
Bryce Thelin
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
