AutoCAD 2013/2014/2015
Product Support
Volker_C
Message 1 of 4 (11,070 Views)
AutoCAD 2013 Annotation Monitor
11070 Views, 3 Replies
04-13-2012 08:40 AM
A new feature in AutoCAD 2013 is the Annotation Monitor which notifies the user if dimensions become disassociated. Many will find this very useful, others may not. It is controlled by the system variable, ANNOMONITOR which can be turned off by setting its value to (0). If you are not familiar with system variables, this is done as follows by typing the system variable (case insensitive) at the command line and then changing the value.
Example:
Command: ANNOMONITOR
Enter new value for ANNOMONITOR <-2>: 0
The Annotation Monitor flags non-associative annotations with a yellow exclamation marker and a red plus (+) icon appears in the drawing status bar. I've listed the sysvar details from the help file below. You may want to take a look at the AutoCAD Help for more details but briefly put, the Annotation Monitor works on Dimension Objects including Leaders and Mleaders.
When changes are made to an object, for example a user has a 3D model which has been dimensioned and a decision has been made to erase (or modify it in another manner) a portion of that model. Once the model has been modified the dimensions for the modified entities are disassociated. That is when the user is notified with a marker placed next to the dimension and by the alert icon in the drawing status bar. When the user selects the marker a menu will appear with options to reassociate or delete the dimension.
A DIMREGEN may be required. From the command line:
Command: DIMREGEN
From the AutoCAD Help file:
ANNOMONITOR
Turns the annotation monitor on or off. When the annotation monitor is on, it flags all non-associative annotations by placing a badge on them.
Type: Integer
Saved in: Registry
Initial value: -2
2 -- Annotation monitor is on.
1 -- Annotation monitor on.
0 -- Annotation monitor off.
-1 -- Annotation monitor off.
-2 -- Annotation monitor off. However, automatically turns on (sets ANNOMONITOR to 2), when a model documentation edit or update event occurs.
More Information
About Associative Dimensions: http://docs.autodesk.com/ACD/2013/ENU/files/GUID-8B7E8C96-C30D-409E-881E-7942871E80DA.htm
To Work with the Annotation Monitor: http://docs.autodesk.com/ACD/2013/ENU/files/GUID-DE2691C0-9E3D-4D6F-8FB5-1709AE4969FD.htm
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker Cocco
Support Specialist
Product Support
bobby
Message 2 of 4 (8,964 Views)
Re: AutoCAD 2013 Annotation Monitor
01-29-2013 09:45 AM in reply to: Volker_C
Yes but why does the annotation monitor flag each mleader as soon as it is created?
Distinguished Mentor
steve216586
Message 3 of 4 (6,813 Views)
06-27-2013 06:57 AM in reply to: Volker_C
Great feature with full functionality for different scenerio and usage!
Wow! :cattongue:
Active Contributor
shunter62
Message 4 of 4 (4,987 Views)
10-15-2013 08:43 AM in reply to: Volker_C
Clicking the icon on the tray is supposed to toggle it off or on, but actually does nothing as far as I could tell. I had to set its values though the command prompt (I don't want it on). I set a new aligned dimension and ithis thing appeared. I don't like having alarm icons showing up when I correctly place a dimension and nothing is wrong.
