AutoCAD 2013/2014/2015
Member
freed765
Message 1 of 11 (2,042 Views)
AutoCAD 2013 and 2014, Fatal Error: d8510004h
2042 Views, 10 Replies
04-17-2013 12:32 PM
Hi there, so I have a very annoying problem. No matter what version of AutoCAD i'm installing, is it 2013, 2014, trail version, there always is this frustrating message when i start program after installation:
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at d8510004h.
I tried to google solution, but nobody have such an information (code).
I have windows 7 64bit, Lenovo Y580 (brand new).
Tried everything, cant' get rid of that. Appreciate any help.
Hello
If you suspect something related to the OneKey Lenovo application ?
Please try to kill the "OneKey Lenovo" Task with the Task manager before installing !
Good Luck, Bye , Pat
pendean
Message 2 of 11 (2,031 Views)
Re: AutoCAD 2013 and 2014, Fatal Error: d8510004h
04-17-2013 01:06 PM in reply to: freed765
So this is a problem on a new PC only? neither program has ever run on it, correct?
Is 2013 fully patched and updated? Did you turn off all background running applications before installing?
Did you "migrate" when installing 2014?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
freed765
Message 3 of 11 (2,020 Views)
04-17-2013 01:39 PM in reply to: pendean
I never tried installing it on different computer, Just now i tried one more time. uninstall autocad 2014, delete register, shutdown every single program in background i can, basically clean install of autocad 2013.
Still FATAL ERROR. only index changed to:
efc90004h.
pendean
Message 4 of 11 (2,016 Views)
04-17-2013 01:46 PM in reply to: freed765
Installation Help from Autodesk (free) may be your next step
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Member
freed765
Message 5 of 11 (1,993 Views)
04-17-2013 05:53 PM in reply to: pendean
I think the installation is properly,
After autocad crashed I clicked "send raport" and it is said that the problem is with Lenovo OneKey Theater. But I tried reinstalling it/uninstalling, still nothing. (index f7d80004h)
I will try something with installation now.
pendean
Message 6 of 11 (1,977 Views)
04-18-2013 05:31 AM in reply to: freed765
Try removing the conflicting application noted, use a quality tool like REVO UNINSTALLER that does a better job than Windows uninstaller, then restart your PC and reinstall AutoCAD per Autodesk's guidelines for removal/reinstall.
Member
freed765
Message 7 of 11 (1,973 Views)
04-18-2013 10:47 AM in reply to: pendean
Ehh, still nothing. The only difference between those errors are first 4 letters/numbers. Now it is f4b80004h.
I'm slowly loosing hope...
braudpat
Message 8 of 11 (1,967 Views)
04-18-2013 11:09 AM in reply to: freed765
Hello
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
Member
freed765
Message 9 of 11 (1,961 Views)
04-18-2013 12:09 PM in reply to: braudpat
So simple! I have to shutdown OnekeyStudio.exe process each time I want to work on AutoCAD, but still it's better than nothing. Thank you very much :smileyhappy:
braudpat
Message 10 of 11 (1,957 Views)
04-18-2013 12:13 PM in reply to: freed765
Hello
Thks, I appreciate the feedback ...
Bye, Pat
