Hi.
I have to add a lot of objects in my dwg. and it takes a lot of time to rotate them manualy once they are placed. usually need to rotate them in pararell with the polyline or line...how to set automatic rotation for object? So when I place object on line it will rotate automaticaly.
Please see picture to expain what I need.
Regards....cez.
Open your block in the block editor.
The tool palettes which automatically open up. The top tab is called PARAMETERS. There is an alignment parameter there., You can place it where you want your block to align by, be it an end point, a mid point, or nowhere near the block.
Howard Walker
Wow, hwalker!
That's awesome... I've been dealing with dynamic blocks for years and I've never even noticed that Alignment parameter.
Thanks.
I'm glad I just occassionally peruse these forums at random.
