AutoCAD Forum
Auto CAD 2014
6 REPLIES 6
david.j.williams423
679 Views, 6 Replies
Auto CAD 2014
I am have an issue whenever I go from 2D to 3D and back I get these lines that are on every intersect/corner facing east/right. I am not sure if I am typing something in the command bar on accident or what. As you can tell I am fairly new so any help would be greatly appreciated.
Thanks!
6 REPLIES 6
Hi David,
I'm going to move your question over to the AutoCAD Forums so that we can get the right crew to help you with your question.
You can check our all our Forums at Forums.autodesk.com if you have other questions, and the one specific to AutoCAD is below, http://forums.autodesk.com/t5/autocad-2013-2014-2015/bd-p/706
thanks again,
Brett Wright
A360 Customer Success
Brett Wright
Thanks Brett. It is driving me crazy!
I've not experienced this issue myself but I would suggest turning off HARDWARE ACCELERATION in AutoCAD to see if that makes a difference. http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
If not I would then try updating your Graphics Card Drivers to a recommended version as tested by Autodesk. http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
What visual style is set when viewing the model space components?
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
That did it. I just resarted the program. I thought that it was a command that I typing by mistake.
Thanks again!
That's brilliant David, please remember to select accept as solution to any answer for other users who may experience this same issue and provide Kudos 🙂
Duncan Brannan
Twitter | LinkedIn
in reply to: david.j.williams423
Hello guys,  am trying to install autocad 2014 but when I get to the "product information" section and enter the Product Key it doesn't like it...therefore I stack...I can't continue with the installation. Why is that? Thanks Maria
”Boost
