AutoCAD Forum
auto cad 2013
3 REPLIES 3
dennysbyhp
334 Views, 3 Replies
auto cad 2013
purchased 2013 license from vendor other than autocad.  when erasing items or copying items, i can only erase (1) item at a time.  with the other versions of autocad i have i can erase or copying multiple items.  is this a problem in the software or is it built into this version?
3 REPLIES 3
Patchy
in reply to: dennysbyhp
Na, you change the PICKADD variable and it will fix itself.
nestly2
Change PICKADD setting to "2"  either by typing PICKADD into the command line, or by unchecking  Use Shift to add to Selection  on the Selection tab in the Options dialog box.
dennysbyhp
in reply to: nestly2
thx it worked
”Boost
