..yet it asks me to recover the drawing every single time. All it ever does is remove the annotative atribute from 20 or so text objects and blow's them up.
Suggestions?
do you save the drawing in the current dwg format or in an older one? If in an older format then try it with the DWG2013 one, save it and reopen it then
You might also try to use command _WBLOCK with option "entire drawing", check then this new drawing.
If nothing helps, can you upload this dwg file?
- alfred -
>> but forced to save down
No, that was no suggestion, to save you drawing to an older dwg format. I just wanted to make sure you don't have set an older format as default.
So the next one is command _WBLOCK. 😉
- alfred -
