AutoCAD Forum
Audit detected no errors
4 REPLIES 4
igi_pop
670 Views, 4 Replies
..yet it asks me to recover the drawing every single time. All it ever does is remove the annotative atribute from 20 or so text objects and blow's them up.
Suggestions?
Lenovo ThinkCenter M920f; Win10pro x64; i5 9500 @3GHz; 16GB RAM; Radeon RX550X
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
4 REPLIES 4
Alfred.NESWADBA
in reply to: igi_pop
do you save the drawing in the current dwg format or in an older one? If in an older format then try it with the DWG2013 one, save it and reopen it then
You might also try to use command _WBLOCK with option "entire drawing", check then this new drawing.
If nothing helps, can you upload this dwg file?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
igi_pop
in reply to: Alfred.NESWADBA
ye, i work in newer ('13) but forced to save down. good catch. will try!
Truth is, everybody is going to hurt you; you just gotta find the ones
worth suffering for.
Alfred.NESWADBA
No, that was no suggestion, to save you drawing to an older dwg format. I just wanted to make sure you don't have set an older format as default.
So the next one is command _WBLOCK. 😉
- alfred -
Alfred NESWADBA
igi_pop
i understood you well, no worries. i DO have it set to an older format,
that's why i sad it was a good clue 😉
”Boost
