AutoCAD 2013/2014/2015
Member
AussieAl1937
Message 1 of 7 (652 Views)
AuatoCad 2013 Error and closes down
652 Views, 6 Replies
07-12-2012 09:11 PM
My computer is a Dell
CPU Intel Xeon W3503 2.4GHz
Ram 6GB
64 Bit
and I using third party Software CADSTA Architectual Rel 2013
When I open some an exisitng dwg file is opens than a fatal error message appears (ea1dad1fh) than I need to close to program and than recover the drawing. When recovering no errors show that they have been fixed!!!!
This appears to be intermittant and can happen with a new file created when I close the programme then reopen,
Error occures.
Can you suggust a fix?
AR
Product Support
VinodBalasubramanian
Message 2 of 7 (624 Views)
Re: AuatoCad 2013 Error and closes down
07-15-2012 08:31 PM in reply to: AussieAl1937
Can you try saving the file to lower file format and see whether you can reproduce the errors while reopening them ?
Did you try doing a repair install of AutoCAD ?
Can you also check whether you can reproduce the same with a different Windows user account with admin rights ?
Please send us a copy of the drawing when you receive this error. We will try to test the file at our end.
Vinod Balasubramanian
ernesto.fraga
Message 3 of 7 (595 Views)
Re: AutoCad 2013 Error and closes down
07-17-2012 08:23 AM in reply to: VinodBalasubramanian
Hello
I have the same problem.
I did everthing that you suggested ( I have down version only to 2010 format).
Audit shows no error (It doesn't show nothing in the command line with a personal template -made in acade 2010- and a acad.dwt)
Autocad crash anyway
Ernesto Fraga
Montevideo - Uruguay
Valued Contributor
jhjirak
Message 4 of 7 (588 Views)
07-17-2012 11:24 AM in reply to: AussieAl1937
what is CADSTA? How much does it cost? Does it allow for intelligent doors/windows/walls?  Do they have a website?
drjohn
Message 5 of 7 (581 Views)
07-17-2012 12:42 PM in reply to: jhjirak
Member
AussieAl1937
Message 6 of 7 (569 Views)
07-17-2012 05:14 PM in reply to: AussieAl1937
Cadsta Arch is a commercial Architectural add on software that works with Acad.  It supersedes the old DRC-Auto which I had used for the pass 15 years. I use it for all my working drawings, Architectural and Structural design and detailing. It can be found at www.cadsta.com.au. the best part of the programme it is very easy to customise the suit any walls and layering config's. For 3D presentation and and interior design work I use Designer Pro form Chief Architect. USA .
Member
AussieAl1937
Message 7 of 7 (568 Views)
07-17-2012 05:16 PM in reply to: VinodBalasubramanian
Will try
