I'm trying to attach a DWG file to my post but it is appearing not to let me. Shouldn't I be able to attach that type of file? Or is there another file type I should be using?
Solved by pendean. Go to Solution.
Yes the issue has been identified and a fix is in the works.
Till then just Zip and attach any files with issues.
Discussion_Admin
We do apologize for the inconvenience.
This is an issue with the platform our forums reside on and effects many nonstandard file extensions. The DWG's just stand out a little more in our discussion groups.
Discussion_Admin
