When i write Mtxt i have to use accents on some vowels. But when i put the accent, the space line between the 2 text line gets thicker.
Then, i have text with various spaceline height, i don't really like that.
Is there a way to stop autocad from giving extra space when i use an accent to get equal space lines between text?
Tx
See the picture
Solved by mathewkol. Go to Solution.
Oh it's working tx (:
I did a little research (4 minutes) but i can't find the system variable to tell Autocad to keep the Text Line Style = exactly
Always
Do you have that information Mathewk ?
Tx
i'd like to know how to set my autocad template to get Exactly by default. Even with an existing drawing how can i set the line space style default to exactly
I don't want to use At least never with new text. TX!
