I'm wanting to place revision tags like you can in inventor, but I can't seem to find them anywhere. does autocad 2015 have them? Thanks in advance!
Solved by ToddRogers-WPM. Go to Solution.
You can also insert the the block into your default drawing template, and it will be available for every new drawing started with that template.
