I'm wanting to place revision tags like you can in inventor, but I can't seem to find them anywhere. does autocad 2015 have them? Thanks in advance!
Solved by ToddRogers-WPM. Go to Solution.
Yep, it's called a BLOCK with an Attribute. That's pretty much your only option. Unless you create a multileader with a block, then there is the whole BLOCK thing again.
You can also insert the the block into your default drawing template, and it will be available for every new drawing started with that template.
