AutoCAD 2013/2014/2015
16 Kudos
Post 1 of 4
Application Plugins Folder must be a .bundle???
730 Views, 3 Replies
03-29-2012 09:02 AM
Concerning the folder "ApplicationPlugins" found in  C: Program File > Autodesk > ApplicationPlugins:
With AutoCAD 2012 I could dump my LISP routines that I use a lot and they would be auto-loaded in any drawing that I opened. I loved it....
With 2013, I try the same thing and it doesn't work. And from what I have been reading, I have to make a folder sturcture with the suffix ".bundle" and create an .xml file in order for these to run....
If this is tru, this is horrible!!! The ability of the  ApplicationPlugins folder from 2012 was awesome.
Am I missing something? Or Is there a way to make 2013 act like 2012 for this folder?
~Greg
I have checked my variables and they are set the same as 2012:
APPAUTOLOAD = 14
I have also ran the command APPAUTOLOADER and selected the "Reload" option and then Listed what applications it sees in the possible folders and it only recognizes folders that are .bundle folders
Distinguished Mentor
84 Kudos
Post 2 of 4
Re: Application Plugins Folder must be a .bundle???
03-29-2012 12:58 PM in reply to: greg.battin
That is correct, the folder must be a .bundle and there must be a PackageContents.xml to control the loading.
If the rules don't suit you, simply use the Startup Suite to load your lisp.
16 Kudos
Post 3 of 4
03-29-2012 01:29 PM in reply to: TerryDotson
Thanks for the (bad news) reply Terry :smileywink:
I will look into the Startup Suite as you mentioned
~Greg
Valued Mentor
14 Kudos
Post 4 of 4
08-02-2013 07:44 AM in reply to: greg.battin
Thank God I am not a CAD manager. The Autodesk pattern is to give you a feature with potential but leave it unimproved for years or create a useful feature and make it less useful the next release. Once I tried the applications plugin folder in 2012 I thought it was actually an improvement, now that I am getting around to trying 2013 and wondering why the lisp doesn't load I find out it is just something else to undo and become program bloat.
Post to the Community
New Post
