Hi Guys,
I’m having a problems running AutoCAD 2014 after been deployed by GPO.
I have downloaded the Autodesk_ME_NetworkAdminGuide_enu.pdf and followed the instructions, everything seems to install fine on workstation but on running the AutoCAD I get a Windows error message.
I have used the AutoCAD 2014 Create Deployment tool 4x times now and I still get the same problem.
Problem signature: Problem Event Name: APPCRASH Application Name: acad.exe Application Version: 25.1.18.0 Application Timestamp: 5114bb70 Fault Module Name: accore.dll Fault Module Version: 19.1.18.0 Fault Module Timestamp: 5114bced Exception Code: c0000005 Exception Offset: 000a4d8f OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 2057 Additional Information 1: 1e00 Additional Information 2: 1e00188f6d53a60a5cb4953ad219789a Additional Information 3: c407 Additional Information 4: c407c1e0e368c8f7ea49d7e346a2fef7 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
Any help would be great
welcome @forums.autodesk.com!
What OS do you have?
Had you disabled antivirus software while installation is active?
Had you full admin-permissions when installer started?
Have you installed the servicepack for AutoCAD also?
Can you upload the log file that is created after installation on a workstation from the deployment package?
Also one important point: when exactly does AutoCAD crash, and did it never start, do you have a network license or a local one, did you finish the activation process (if it's a local license)?
- alfred -
Hi Alfred,
Sorry for the delay
What OS do you have? Windows 7
Had you disabled antivirus software while installation is active? - No, We use Sophos AV and never had too
Had you full admin-permissions when installer started? - Yes, Im the Network Administrator
Have you installed the servicepack for AutoCAD also? - Yes, Though the deployment software
Can you upload the log file that is created after installation on a workstation from the deployment package?, - Will do a freah install today and post log
AutoCAD crashs after double clicking the icon, We have a network license
Hi Dean,
I have tried reinstalling it via GPO but it just does the same.
If i run the installer manually on a workstation it works but ask for a license as it should.
