AutoCAD 2013/2014/2015
JamaL9722060
Message 1 of 3 (607 Views)
Annotative block moves when annotation scale changed,
607 Views, 2 Replies
03-13-2013 03:32 PM
The solution for this problem is mentioned in the link below but sounds not to be helpful:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11938250&linkID=9240617
I got a block that contains an attribute (attached) and created on layer zero while the current annotation scale is 1:100. As this annotation scale is changed (say to 1:200 or 1:50) this block moves from its original place to another one (as shown in the attached screenshots)
How to control this behavior?
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
your problem is not really the block moves, but the insertion point of this block is far away (lower-left) from the geometry within the block.
To proof that select the blockreference, zoom out as far as necessary so you see the grip-point (= insertion point) of this block-insertion. Then change the annoscale and select the block-insertion again ==> the insertion point does not move.
Solution: redefine your block with a correct insertion point, then everything will work as designed.
- alfred -
Alfred.NESWADBA
Message 2 of 3 (601 Views)
Re: Annotative block moves when annotation scale changed,
03-13-2013 03:41 PM in reply to: JamaL9722060
- alfred -
Alfred NESWADBA
JamaL9722060
Message 3 of 3 (563 Views)
03-15-2013 02:34 PM in reply to: Alfred.NESWADBA
Many thanks Alfred for the help. It worked like a charm!
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
