AutoCAD 2013/2014/2015
0 Kudos
Post 1 of 5
Aliasedit in AutoCAD 2014
2951 Views, 4 Replies
04-17-2013 01:36 AM
Even though aliasedit dialogue box shows I have changed 'C' to copy and 'CI' to Circle; they don't actually work when drawing.
Is this a bug or has something changed in 14?
Rich
well, tried it now and my problem is one step before. When I run _ALIASEDIT and modify the C-alias from CIRCLE to COPY, confirm the change and end the dialog with OK .... and then restart _ALIASEDIT ==> I see that my changes were not saved.
I tried then (input in the commandline followed by <ENTER>)
(findfile "acad.pgp")
==> that gives me the position of the pgp that AutoCAD is currently using. I opened that file then with notepad, modified the C-alias to *COPY, saved the file, run command _REINIT (with option to reread the acad.pgp) ==> it's ok now (hopefully for you too :smileywink: ).
- alfred -
1,219 Kudos
Post 2 of 5
Re: Aliasedit in AutoCAD 2014
04-17-2013 02:58 AM in reply to: richcole2004
start command _INPUTSEARCHOPTIONS ==> uncheck there first all options, then try it again, and as long as it's working now switch each of these options back to on and verify the command-line input again.
If that does not help, then to your info:
please describe, what's then happening when you enter C<ENTER> in your command-line?
- alfred -
Alfred NESWADBA
0 Kudos
Post 3 of 5
04-17-2013 03:16 AM in reply to: Alfred.NESWADBA
Thanks for your reply.
I unchecked all the options as suggested and it still does the same.
While drawing I use C <ENTER> it drawings a circle even though my aliasedit dialogue box has C for Copy
While drawing I use XR <ENTER> it opens the new XRManager even thought my aliasedit dialogue has XR for ClassicXREF
Basically it is ignoring my pgp for commands but aliasedit is picking them up.
Rich
1,219 Kudos
Post 4 of 5
04-17-2013 03:30 AM in reply to: richcole2004
- alfred -
Alfred NESWADBA
0 Kudos
Post 5 of 5
04-17-2013 03:50 AM in reply to: Alfred.NESWADBA
MAGIC!
Cheers Alfred!
