Hi everybody,
Have anyone dwg for AIA layers in architecture ??
if there is full drawing that will be more good.
Try this lisp in an empty file http://cadtips.cadalyst.com/standardize-data/aia-standard-layers
and here (bottom reply) http://forums.autodesk.com/t5/autodesk-architectural-desktop/aia-layer-standard-dwg/td-p/1262144
I believe the AIA uses the National CAD Standards recommendations for layering with Discipline-Major-Minor-Status structure. AutoCAD Architecture used to provide all the layers in the template drawings but has since moved to a create layer on-demand approach using layer key styles. I suggest you download a trial copy of AutoCAD Architecture and play around with it to discover its layering features.
