first of all I'd like to say that I am aware of the fact that I've posted in the wrong section -- however I failed to see any Advance Concrete forums here.
I have a educational version of AutoCAD 2015. Right now I am learning how to draw fast, and try to install Advance Concrete 2015. Sadly, I fail to do so. When I try to use the 2015 version of AC, I have it in English rather than in Polish (even though I've downloaded the polish version and the extracted content has pl-PL folder inside). The installer asks me to choose content language and I pick polish(Polski), but it doesn't swap into Polish but stays in English. Same after the installation, AutoCAD is in Polish while the AC addons are in English.
I've tried installing Advance Concrete 2015.1, however I do miss "Browser download" option on the website.The downloader (which is the only option available) pops a "Network error, check connection" at Microsoft software (.NET Framework 4, Visual C++ 2012 and so on).
How do I install this software?
Any help would be greatly appraciated.
Thank you!
Solved by natasha.l. Go to Solution.
try to download the product from the >>>Autodesk Virtual Agent<<< and install it then.
HTH, - alfred -
Thank you for the reply.
When I choose the "Advanced Concrete" download link and pick the 64-bit version, a window pops up with "File not found".
just a confirm, same for me, hopefully someone from Autodesk sees that.
If you have a subscription create a support request about that.
- alfred -
Bumping the thread.
Hopefully someone from the Dev Team will see this post.
plz help me immediate.....
I install advance concrete 2016 64 bit softwere...
this softwere can't open...
no window in desktop...
plz answer me....
Welcome to the community...
All this demanding you are doing isn't a polite way of asking for assistance.
To me it sounds like you never had a successful installation. If you go to Windows Control Panel/Add&Remove programs due you see the application installed?
Mark Lancaster
& Autodesk Services MarketPlace Provider
First of all, create a new post. Why are you posting to a post that's 3 years old?
Within the new post, provide screenshots, error messages, and other helpful information pertaining to the issue you're having.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Hello @masermen,
I understand you are trying to install Advanced Concrete on your computer. I have attached a direct link:
Autodesk Advance Concrete 2015 Polish Win 64bit R1
Autodesk Advanced Concrete 2016 Win 64bit
Please let me know if it worked out. Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
