The attached pdf's are from the powerpoint lecture slides included with the textbook Technical Drawing 101 with AutoCAD 2015 by Smith, Ramirez, and Schmidt.
TIP, I used to add a separate piece of text, or floating attribute for things like METERS SQUARED. Using MTEXT it's easy...
METERS SQUARED (m^2) SUPERSCRIPT WITH MTEXT
Create a stacked fraction (TYPE 3/4), it will automatically stack is with smaller text, hightlight it, the RIGHTCLICK, STACK PROPERTIES.
Change the STYLE to TOLERANCE, and UPPER TEXT TO (2) and LOWER TEXT (leave blank) this will give you and actual meters squared as one object.
