AutoCAD 2013/2014/2015
Member
0 Kudos
Post 1 of 2
Adding contour lines to CAD
1894 Views, 1 Replies
10-09-2012 07:49 PM
Hi, I'm pretty new to AutoCAD, and I was wondering how I would go about adding contour lines to a map? I entered roughly 200 points (x, y, and z values) into an x-y plane on AutoCAD and figured that if I were to add contour lines (1' elevation difference), it would rely on the z axis. In short: how do I add contour lines if the points are all plotted? Thanks in advance!
*Expert Elite*
474 Kudos
Post 2 of 2
Re: Adding contour lines to CAD
10-10-2012 04:50 AM in reply to: samfisher12
You posted in the vanilla AutoCAD group, so I guess you are using this and not AutoCAD Map or Civil 3D, right?
You'll need some sort of add-on program like this http://dotsoft.com/mapworks.htm unless you want to manually triangulate those points and then connect like elevations to make the contours yourself.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
