I am the engineer for a furniture manufacaturer. We have multiple factories from different place make all of our product. Every once and awhile, we have a problem were the factory accicentally starts using an old drawing for their production. The process of creating these factory CADs is that I make the first CAD with the designer. After that innitial CAD is complete, we send it to the best factory that can produce that sort of design. That factory then re-engineers the CAD to fit their processes, and send their factory CAD to me for approval.
The problem is that all I can do at this point is send an email saying "approved". Is there a better way to do this? In MSword, there is a way to put a "stamp of authenticity" or approval on the document. Is there a way to do something like this in AutoCAD?
Thanks!
Hi
There is a possibility, try to use Digital Signatures in AutoCAD
Hope this helps you
Cheers
Another alternative would be to use a document control system like Vault where drawings and documents must be checked out through an interface. That way, the system guarantees that only the most recent approved version is available to others. It can also control who has access to check in updated versions.
