AutoCAD 2013/2014/2015
Distinguished Contributor
DRoam
Message 1 of 5 (163 Views)
Add to available lineweights in existing drawing
163 Views, 4 Replies
02-06-2013 06:45 AM
Sorry if this question's been asked and answered many times before, I tried a few searches and couldn't find anything similar.
I'm wondering if there's a way to change/add to the list of available lineweights in the dropdown lists in the layer manager. I want to have a thickness of 0.125", but that isn't available. I found that if I issue the STYLESMANAGER command, I can edit lineweights in existing .ctb/.stb files, but I don't know now to transfer that to be available in an existing drawing. Can I just assign a ctb/stb style to my drawing?
Thanks in advance for any advise!
*Expert Elite*
pendean
Message 2 of 5 (139 Views)
Re: Add to available lineweights in existing drawing
02-06-2013 11:23 AM in reply to: DRoam
Are you using STB or CTB? They don't work the same way and the latter offers no option to pick from LAYER command.
And I have to ask: which column in LAYER are you using exactly?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
DRoam
Message 3 of 5 (132 Views)
02-06-2013 11:45 AM in reply to: pendean
Honestly, I have no idea if the drawing is using STB or CTB... I don't have any knowledge about what those are or the difference between them.
The command I'm issuing is actually AMLAYER, and the column is the "Lineweight" column. AutoCAD gives me a dropdown with several options, none of which are 0.125". I've got a screenshot below:
Does that answer your question?
*Expert Elite*
Patchy
Message 4 of 5 (124 Views)
02-06-2013 12:19 PM in reply to: DRoam
That is all the lineweight available, can not add or delete them but you can use CTB to plot to any width.
15 min. video here explains a lot
http://www.youtube.com/watch?v=YiRUtGyiNsg
**Master
dmfrazier
Message 5 of 5 (111 Views)
02-06-2013 02:00 PM in reply to: DRoam
You can easily discover whether you're set up for CTB or STB in the Plot dialog, expanded, in the upper right corner, drop down the Plot Style table list and see what file type shows.
If the advice you've received so far has not helped, since you are running Mechanical, you might get more pertinent help by posting in the Mechanical Discussion area.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
