I can't seem to find how to edit properties of rectangular arrays using VBA. Same goes for polar or path arrays.
For example, if i draw a circle in an empty drawing and then create a rectangular array using the command ARRAY, AutoCAD will typically creat a default array with 3 rows and 4 columns. In VBA, ThisDrawing.ModelSpace.Count = 1 and ThisDrawing.ModelSpace(0).ObjectName = "AcDbBlockReference". However, i can't see or modify any array propertiessuch as row count, row spacing, row elevation increment, included angle, etc.
Any ideas?
Solved by pendean. Go to Solution.
