AutoCAD Forum
acad lt 2014
13 REPLIES 13
Message 1 of 14
rw
276 Views, 13 Replies
acad lt 2014
Acad cannot open all of my files, only some.  I have sp-1 installed, this may have happend automatically.  Could this be the issue?  All my files can be opened on other machines running acad lt 2014 without the sp-1.
13 REPLIES 13
Message 2 of 14
rkmcswain
in reply to: rw
When you say "cannot open a file" - what do you mean exactly?
Does it crash when you try to open a particular drawing?
Does it just give you a message such as "invalid drawing file"? and then return you to the file selection dialog?
Something else?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 14
rw
in reply to: rkmcswain
Autocad opens, it begins to read the file, and stops at between 21% and 34% and then says acad not reponsive
Message 4 of 14
Alfred.NESWADBA
in reply to: rw
what happens if you try to open the drawing using command _RECOVERALL (instead of _OPEN)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 14
rw
in reply to: Alfred.NESWADBA
I just tried using the recover all command
i get a message that acad is not responding
this is on a machine running windows 8.1, if that matters
Message 6 of 14
Alfred.NESWADBA
in reply to: rw
And what os do the other workstations have installed?
If you copy the file to your local drive and open it from that postion (hoping it has no XRefs), same issue?
- alfred -
Alfred NESWADBA
Message 7 of 14
rw
THE OTHER MACHINES ARE RUNNING WINDOWS 7
I JUST TRANSFERRED THE FILE TO THE HARD DRIVE ON MY COMPUTER, AND IT OPENED TO 24%, STOPPED, AND THE MESSGE IS "NOT RESPONDING"
Message 8 of 14
Alfred.NESWADBA
in reply to: rw
Is there any other system on Win8.1 that can open that drawing without a time lag?
Did it work before you installed SP1? Or was AutoCAD LT just installed and never worked?
You might try to start AutoCAD as administrator, does that make differences?
- alfred -
Alfred NESWADBA
Message 9 of 14
Patchy
in reply to: rw
2014 running with 8.1 ?
Maybe that's the problem.
Message 10 of 14
rkmcswain
......and/or any other user new to this machine, so that you are working with a fresh Windows profile and AutoCAD LT profile
Message 11 of 14
rw
FIRST, I DID NOT INSTALL SP-1, I THINK IT HAPPENDED AUTOMATICALLY.
BUT, I WALKED AWAY FROM MY MACHINE FOR ABOUT 1/2 HOUR AND WHEN I CAME BACK A FILE HAD OPENED WHICH HAD BEEN NOTED "NOT RESPONDING"
SO, SOMETHING IS JUST SLOWING DOWN SOME FILES.
I WOULD REMOVE SP-1 IF I KNEW HOW.
Message 12 of 14
rw
MY TECH, WHO IS GOOD WITH ACAD, TRIED TO OPEN AS AN ADMINISTRATOR, SAME PROBLEM
Message 13 of 14
rkmcswain
in reply to: rw
It's possible that the drawings suffer from the DGN Linetype Bloat issue.
Message 14 of 14
Alfred.NESWADBA
in reply to: rw
If you look to the taskmanager while AutoCAD is loading a file, what processes use most of the power?
- alfred -
Alfred NESWADBA
”Boost
