I am using an Educational version of AutoCAD for Mac while studdying, once I purchase a full copy will I be able to remove the stamp from drawing I have started writing or do I need to start all over again with all my projects?
If you buy 2015 full version of autocad you can get rid of the edu. stamp
welcome @forums.autodesk.com!
Besides of the technical solution that 2015 does not show the plot stamps you should be aware of the licensing! All drawings created with the educational version are only for non-commercial use. So using these drawings (or parts of it) is not allowed for commercial purposes.
- alfred -
