AutoCAD Forum
Acad 2015 - Custom Galleries
6 REPLIES 6
Dylan_Corkill
326 Views, 6 Replies
Does anyone know if you can create your own galleries in a custom cui file?   We have an extensive block library and I would like to get away from using the ald slide library's that we have.
THasnks
Dylan
6 REPLIES 6
pendean
in reply to: Dylan_Corkill
Toolpalettes are designed for that functionaility: but you can sure do it the long/hard way in CUI if you want (not sure 'galleries' is a user option, I don't see it in 2015).
RAMasterson
pendean
in reply to: RAMasterson
I may have misunderstood, I though the OP wanst to create custom Galleries and not just see images through INSERT command (basically ADCENTER on the Ribbon).
How does someone create unique Galleries of custom block libraries in 2015?
Exactly.  I haven't been able to find any documentation or anything within the cui that will let me create one.
Anyone from Autodesk got an ansewer for this one?
dgorsman
I don't think "galleries" are created, but rather presented in the same manner as text and dimension styles are in the Annotation tab of the Ribbon.  It shows a quick preview of the blocks that are defined in the drawing, same as the mini-image in the Insert dialog.
pendean
That's what I concluded as well: Galleries are not a user feature.
Back to Toolpalettes or ADCENTER for the user asking the question.
”Boost
