Just loaded Acad14. When go to design center, cannot find my old blocks such as furniture,desks
plumbing etc. Where are they located. I tried to migrate settings, didn't help
Are you referring to the sample files installed with AutoCAD? These are typically found in, "C:\Program Files\Autodesk\AutoCAD 2014\Sample\en-us\DesignCenter".
You can use the ADCNAVIGATE command to set the path as a default to this location or a custom location pointing to your block libary.
Hope this helps.
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
You may want to compare your Support File Search Path under OPTIONS with your previous CAD install if you can.
It may be that all the Paths you had before are not a part of this install.
Though as Volker pointed out all you may need to do is find these once in ADCENTER and then they will be readily available.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
my en-us file is empty. am not able to find blocks like furnitures,windows,etc .
yes. same problem here. under en-us.... there are a few files but all empty and no design center tab.
