Hi
Wondering if anyone else has issues with SolidEdit - Shell not working? 2014 all was fine, 2015 it does nothing...
Tried on several machines
Solved by Oli. Go to Solution.
Can you attach *.dwg file that exhibits this behavior?
Have you installed all Service Packs?
Hey Guys,
Thanks for the rapid reply, I can confirm I am running with the lastest SP.
I had another go last night and it seems to be a save format thing -
I used to use 2014 - saving in a 2007 Format
Now using 2015 - saving 2010 Format
It seems anything I worked on pre-upgrade saved in 2007 format I have the issue with, but anything new is fine.
Which is fine as I can work around that.
