If you can, direct me to someone/thing, I can learn from.
I have a string from the properties box, and I wish to understand what I am liiking at.
;;;{\fArial BlackIb0Ii0Ic0Ip9;\c1677690;PROCESS RM}
i understand the "Arial Bl.ack" is the font, and I understand that "PROCESS RM" is the text I used. The capital I's are supposed to be the separator lines in the string, I thought the would work best when showing the string from the properties box.
Thank you to any one who can stear me in the right direction.
HD
Solved by nestly2. Go to Solution.
