Hi, I searched alot of posts and forums, but couldn't find the right answer to this error.
I posted this under AutoCAD, but the error which I came up was with DWG TrueView 2014.
I get de HDI error if I start DWG TrueView without the /NOHARDWARE paramater, so I changed the shortcut, but the filetype association doesn't look at this, so if yoy start a DWG-file from the explorer, then DWG TrueView starts without the /NOHARDWARE parameter.
After alot of troubleshooting I found an solution which solved this problem for me, maybe that it will help others or get an discussion started about this issue to get a better solution.
Delete the registry folder HKCU\Software\Autodesk\DWG TrueView\ R12.
Start DWG TrueView with the /NOHARDWARE option and then close it.
Copy/paste the following keys in a .REG file (or download the attachment) and import the file in to your registry.
Then you can open a .DWG file from the explorer in DWG TrueView 2014 without the /NOHARDWARE option.
REGEDIT4
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\3DGS Configuration]
"FirstRun"=dword:00000001
"FeatureData"=hex:00,00,00,00,00,00,00,00,00,00,00,00,
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\AutodeskApps\AcadOrbit]
"WalkSettingInfo"=dword:000000a6
"WALKTHROUGHSETTINGSINFO"=dword:0000321e
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\FixedProfile\Drawing Window]
"Show"=dword:00000003
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\FixedProfile\Editor Configuration]
"PickFirst"=dword:00000000
"Grips"=dword:00000000
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\FixedProfile\General]
"MeshMaxFaceValue"=dword:00000001
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\MiniDump]
"SessionStartCount"=dword:00000003
"AccumulatedUptime"=hex(b):74,5a,ae,05,00,00,00,00,
"AccumulatedCalUptime"=hex(b):45,77,4a,11,00,00,00,00,
"SessionCleanCloseCount"=dword:00000003
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\Profiles\<<Unnamed Profile>>\Variables]
"DIMCONSTRAINTICON"="0"
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\Profiles\<<Unnamed Profile>>\Editor Configuration]
"TraySettingsShowNotifications"=dword:00000000
[HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R12\dwgviewr-B001:409\Profiles\<<Unnamed Profile>>\General]
"TBCUSTOMIZE"=dword:00000000
