AutoCAD 2013/2014/2015
Active Member
nicole.ravasini421
Message 1 of 9 (421 Views)
3D trim newbie! help!
421 Views, 8 Replies
10-05-2012 08:41 AM
Hi! i'm a Autocad 3D newbie! Have some problems to figure out how to trim a solid from a sphere. well here's an image that will explain better!( it's the pink part from the green)
thank you so much !
Patchy
Message 2 of 9 (416 Views)
Re: 3D trim newbie! help!
10-05-2012 08:44 AM in reply to: nicole.ravasini421
Trim doesn't work, use SUBTRACT
Active Member
nicole.ravasini421
Message 3 of 9 (414 Views)
10-05-2012 08:45 AM in reply to: Patchy
the subtract command subtracts the whole pink solid and leaves the empty shape in the sphere, I just need to cut the part that sticks out from the bottom of the sphere!
Patchy
Message 4 of 9 (405 Views)
10-05-2012 08:52 AM in reply to: nicole.ravasini421
Attach your drawing here.
Active Member
nicole.ravasini421
Message 5 of 9 (403 Views)
10-05-2012 08:55 AM in reply to: Patchy
Patchy
Message 6 of 9 (389 Views)
10-05-2012 09:56 AM in reply to: nicole.ravasini421
Subtract command.
Active Member
nicole.ravasini421
Message 7 of 9 (384 Views)
10-05-2012 10:05 AM in reply to: Patchy
thanks!!
but how did u do it? subtract and?
Patchy
Message 8 of 9 (381 Views)
10-05-2012 10:15 AM in reply to: nicole.ravasini421
Thanks for the challenge, it was not as EZ as I thought.
I had to make a copy of the model, SUBTRACT the unwanted parts, then SEPARATE them, after that I move them back to the original position.
Active Member
nicole.ravasini421
Message 9 of 9 (365 Views)
10-05-2012 12:03 PM in reply to: Patchy
Thank you!!! gonna try to repeat it myself, gotta learn!!!!
thanks again!
