I'm currently facing some issue while I have done my 3D models using autocad, bear in mind that I'm completly new with Autocad, and that why I'm posting here, asking for best practice or at least been guide to the proper way,
I have to scale down the yellow part (only the inside), but I'm not sure what has to be done, I'd like to avoid having to redesign the whole project
I remember that the base line has been define as region if that help
any help would be appreciate
thanks,
Quentin.
Solved by nestly2. Go to Solution.
If you only need to change the diameter of one feature, you may be able to use the SOLIDEDIT > Offset Faces tool. If you need to change the whole piece, perhaps SLICE it off modify it, and then re-UNION it. (or just recreate that portion from scratch) If it's a simple matter of SCALING, just rescale the sliced part as a 3D solid, however if you need to modify the shape, it may be easer to explode it into Surfaces/Region, delete all but the top or bottom profile (region) Explode that again to further reduce to 2D geometry, modify as needed and re-extrude into a solid.
Nesly you're a star!
I wish I can have your skill - be able to reproduce the pieces and show me that by a video is the best way!
I'll give a try soon,
if you're planning to make private course on how to use autocad, I'll be your first student!! 🙂
