I have just installed my new MakerBot Replicator (desktop 3D printer). However, I am having difficulty get the my .stl file to print. The .stl file was oringinated in AutoCAD 2014 and is a small mechanical part I designed. I have tried the HELP section is AutoCAD, but that is trying me to purchasing a 3D printing service, when I have thE MakerBot to do the printing for me. I am so confused.
I have attached my STL file and the CAD file I made it the .STL from.
Solved by JDMather. Go to Solution.
Solved by Patchy. Go to Solution.
When I first added it to the MakerBot setup, it did say it was a scaling issue. I went back to AutoCAD and scaled it down a lot and now it is working in the 3d printing. I'll see how it goes.
Thanks for your help!
Two commands you will want to know.
-dwgunits and read the command line for your document units. (with the preceeding - sign)
stlout to export your stl file.
