Hello wonderful AutoDesk Community. So I have fully designed a functional part that I intend to use and would like to 3D print it. My only concern is this part was created using multiple extrusions of objects and such instead of cutting into a giant prism like sculpting. I grouped together these objects so they move as one on screen, but when I print it how can I be assured that it will be in one piece? Attached is a screenshot of the part.
Solved by nestly2. Go to Solution.
I am not familiar with all the requirements of 3D printing, but if you need/want it to be one solid object, use the UNION command on the Ribbon, or from the Command Line.
