I am using AutoCAD 2014 and trying to get started with 3D modeling. I have created a 3D model by using the Revolve command to sweep a 2D path around an axis. My 3D model looks sort of like a barbell - a narrow shaft in the middle with two cylindrical weights on each side. I wanted to put some text on the sides of the weights. I used the DTEXT command and I made sure the Z coordinate for my text is not "behind" the weight I am trying to label. I have an Isometric view setup for my 3D model with the Visual Style set to 'Conceptual'. In this view, my text is "outlined" in the color corresponding to the layer I placed the text on, but it is "filled" with a darker shade. I can read the text ok on my computer screen, but when I print to my monochrome printer, it is very difficult to read. I'd like to find out if/how I can make my text appear in the 'Conceptual' Visual Style with the same color for its outline and its fill. For this particular drawing, I would like these both to be white.
Any advice will be greatly appreciated.
Thanks in advance,
Paul
Solved by nestly2. Go to Solution.
I'll assume this is a TrueTypeFont.
TrueTypeFonts generally aren't well suited for a 3D environment. Not only does font smoothing not work when TT text is at non-zero elevation, They aren't properly filled except in 2DWireframe visual style. I'm not sure I understand your intent fully, but you may find better results exploding the text with Express Tools Text Explode (TXTEXP) and "filling" the outline manually with a solid hatch, or by extruding the letters into 3DSolids.
Hi Nestly2,
Thanks for your response. Yes, it is a truetype font. I started my drawing with the acad.dwt template that comes with AutoCAD. I didn't create or change any text styles after creating this drawing, so my text style is set to "Standard" and when I go to "Manage Text Styles", I can see that this "Standard" Text Style is linked to the TrueType Arial font.
I am not trying to do anything fancy. I said my 3D model resembles a barbell, but it is actually just a conceptual diagram representing two wound spools of material mounted on a single shaft, like if you put two rolls of toilet paper on a single shaft to support and unwind them. The machines I build unwind and rewind spools of material like this. All I want to do is place labels like "A", "B", "C", and "D" at strategic places on my Isometric View so that they will be readable if I print (even on a monochrome printer). I have never used the express tools text explode or extruding text into a 3D solid. I can read up on these things and give them a try, but first I'll ask...considering how basic what I'm trying to do is and the fact that I don't need this to look great (just readable on a printed page), can you recommend another font (or type of font) that I can use that might make my task easier.
Thanks again for your help!
Paul
Thanks Nestly2,
That looks great and switching to romans.shx definitely made my text more readable on the printed page. It's probably already good enough for what I am trying to do, but if possible, I'd like to make the text a little bolder. The text in your animation looks bloder than mine, even though I used the same font. I'm just curious if there is a setting I can use to make it look bolder? I think I've looked in all the obvious places and I can't seem to find anything.
I have attached my actual drawing, if you have time and don't mind taking a quick look at it.
Thanks again,
Paul
The reason my text appears to contrast more is because I was using a white drawing background. It's just a diffence in how AutoCAD shades for differnt conditions. Try changing the layer color for the model, or change the layer color of your text. I don't think you can bold shx fonts, but I'm really not sure.
Thank you Nestly2,
I'll play around with different layer colors for my model and/or text to see if I can make my text stand out a bit more, but even if I can't, I think what I have now will do the job.
You've been a huge help - thanks again!
Paul
