I want to place 3d letters into a dwg. I need them to be objects.
What I am doing is using Autodesk's 3rd party program to make IFC's (Fabrication CADMEP). I have to change regular extruded objects by convert3dmodel command. Then I use command IFCE. From there I make a 3D Pdf with BlueBeam. I cannot get Project Managers to download Navisworks freedom and I refuse to use screen shots. I just need text in my 3d pdfs.
What is the best way/font to make 3D letters and then make those into extruded objects (via explode the like).
Solved by nrz13. Go to Solution.
Solved by Kent1Cooper. Go to Solution.
@Anonymous wrote:I want to place 3d letters into a dwg. I need them to be objects.
Express Tools>Text>Explode Text then clean up the results, probably PEDIT and JOIN, then EXTRUDE.
I always explode the text, run the REGION command on the text, then the UNION command to merge all the regions together, and finally, EXTRUDE.
Yes, I always use TXTEXP to explode the text. That wasn't clear in my post, but I didn't even think you could use the regular explode command on text, either.
There used to be a cracking little tool called T2G, downloadable from the Autocad exchange site, unfortunately there isnt a version for 2016 as yet.
