Hi
Is there a way to edit vertices of a 2D polyline so that height of vertices be specified?
Solved by ToddRogers-WPM. Go to Solution.
Hi
Thank you for your reply.
I meant if I have a 2D polyline. How can I edit vertices to specify height to change it to 3d Polyline.
Hi
Thank you very much. This LISP is usefull. Why it isn't included in AutoCAD as a command?
