I've opened a drawing from someone else, created in AutoCAD, in AutoCAD 2015 and appear to have a lot of extra lines shooting off in strange directions. If I zoom right out, they disappear but reappear when I zoom back in
Has anyone else experienced this? Or is my graphics card about to die. This is on my laptop and I have yet to check on my home PC
Screenshots below, thanks in advance
David Ripley
cad4theatre
Solved by David-cad4theatre. Go to Solution.
Hello
YES they are some strange graphic problems with 2015 ...
1) Have you updated your graphic card driver ?
2) Have you tried to run with LINESMOOTHING = 0 (OFF) ?
3) Have you tried to run with LINEFADING = 0 (OFF) ?
4) Have you tried to run with Hardware Graphic Acceleration DISABELD ?
Have a NVidia graphic card ?
Patrice BRAUD
Pat
LINESMOOTHING cured it
I guessed it was something like that - something to add into my coursework, I guess
DAvid
Hello
You are lucky ...
Patrice BRAUD
I have the same issue for ACAD 2014. A forum seach for this version doesn't get any results/answers. "Linesmoothing" doesn't work in 2014 (no such command).
Any ideas for 2014?
try VSE (VSEDGEJITTTER)(ENTER) MAKE VALUES AT 0.
@David-cad4theatre wrote:I've opened a drawing from someone else, created in AutoCAD, in AutoCAD 2015 and appear to have a lot of extra lines shooting off in strange directions. If I zoom right out, they disappear but reappear when I zoom back in
David Ripley
cad4theatre
