Okay, maybe something is not working correctly or AutoCAD changed its functionality but I cannot key in the location I want to drop an object that I'm moving. Attached is a border template I'm working on that I want to move using the bottom left corner and using this as the insertion point, move to the 0,0,0 coordinates. When I highlight everything to move, select the endpoint (bottom left corner) then key in 0,0,0 the object temporarily move to that location. As soon as I strike the Enter key, the objects move right back to their original location. I'm I doing something incorrectly?
cheddarthief
Solved by sthompson1021. Go to Solution.
Solved by tmccar. Go to Solution.
Use #0,0,0 to move it. Use # To define absolute location and @ for relative. You can also change this in settings. I've attached the fixed dwg.
Press F12 (dynamic input) and try the move again (or toggle it using the icon at the bottom of the screen).
tmccar,
That's perfect. I didn't see that the dynamic input was not as desired. That was all it took. Thanks.
When Dynamic Input is OFF, AutoCAD defaults to Absolute Coordinates
When Dynmaic Input is ON, AutoCAD defaults to Relative Coordinates
As stated above, # and @ will force the mode regardless of the "default" setting.
Don't mean to nit-pick but what you said is true if you have relative coordinates selected for pointer input in drafting settings. If you have absolute coordinates selected, it will use absolute no matter if dynamic input is on or off.
When I said "defaults" I meant that's the way AutoCAD is initiatially configured to work, but you are correct that the user can change the "default" Dynamic Input behavior from Relative to Absolute. Thanks for the clarification.
Is there a way to set the default dynamic input behavior in the options in AutoCAD so I don't have to hit the F12 each time?
You can go into DRAFTING SETTINGS and select the dynamic input tab. Then in settings under pointer input, you can select absolute coordinates.
Especially when using coordinates - to enter them manually ,Dynamic input is not working well , Its irritating,,that's why I never use Dynamic input. I like the old good command line input.
