Hopefully something simple. Just got my 2015, and I can't seem to find where the setting is give me more lines (history) on my docked command line.
In previous versions, I simply stretched it out with my mouse. I like more history so I can see current settings as I work.
Thanks in advance, cheers, Shari
Solved by Shari-aec. Go to Solution.
Tried it before I posted. See image, nothing there for "lines of history". Again, I just got 2015, still getting used to it.
I'm wondering if it is because of your command line placement - the history normaly scrolls up from the command prompt (when it's at the bottom as in my case).
Becasue you have yours sandwiched between the top "menu" and the Ribbon, it has no where to "scroll". Here is a screen shot showing mine, and you can see in behind the pop up menu the prompt history.
Thanks! That provided the workaround I needed. I docked the command line at the bottom, then STRETCHED it bigger. Then I grabbed it and docked it back up at the top, and the number of lines remained.
Thanks again, this would have driven me nuts. Cheers, Shari
