Is there a way to get the arrows back in 2015 for the layout tabs? The flyout tab in 2015 is clunky and adds steps to my process. And please don't tell me to use sheetsets 🙂
You can use (quicker) keyboard shortcuts like in the previous versions (2004+), Ctrl+PgUp and Ctrl+PgDn
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5976
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
I agree that the flyout is a bit clunky. Sorry that I don't have a solution for you.
But, since you brought it up...
I do love sheet sets! Wondered what we did without them!
Hi, guys, and thanks for your replies. Sorry I haven't gotten back sooner, but I'm glad to have deadlines.
It only really bugs me when I need to print a couple of sheets that always happen to be at opposite ends of the layout list 🙂 It doesn't make sense to create a sheetset for the one time I need to print a floor plan and a building section together into one pdf.
Have a great weekend.
@SaturnRanchArchitecture wrote:Hi, guys, and thanks for your replies. Sorry I haven't gotten back sooner, but I'm glad to have deadlines.
You could use PUBLISH and just select the layouts that you want from a list.
I had turned this in a couple years ago as a WISH LIST
I still like the tabs at the bottom of the drafting area, not the new way in 2015
If they would make the tabs a "Strechable Pull Up" like the command line, everyone could
select how many were visible.
Ron
Not sure if this will help but if you right click on the layout tab you can make the tabs on a separate line than the status bar. not sure if that cures what you talking about.
