I have changed crosshair size to 100% at option/display. In selection mode, the crosshair size keeps 100% with selection window. In previous version, crosshair disappeared in selection mode/window. Can we do the same in 2015?
Will Autodesk pesonnel make the changes as described by linkboy? I'm getting frustrated with some of the features forced on me. I don't want to unlearn the way I use AutoCAD commands and features and relearn a new set of ways of using AutoCAD.
During all the years of using the selection window and selection crossing window the crosshairs have disappeared. I don't need the crosshairs during a selection. It's information I don't need.
How about listening to us users? You at Autodesk don't seem to be users of AutoCAD to make a living by creating construction documents (drawings). You at Autodesk seem to have your own agenda and seem to don't care about us who buy your software.
It works fine for me in 2015.
This is the drawing window with cursorsize set to 100
This is the same drawing window during the ERASE command.
I think the complaint is that the crosshairs no longer disappear during windowing. I do think it's a potential problem when SELECTIONAREA is disabled as shown in the screenshot because it makes the selection window less clear, particularly that the crosshairs obscure the "dashed" boundary of a crossing window.....probably less so when Selection area tinting is enabled.
Ok.
OP used the phrase "selection mode" twice, which means 'while selecting objects' to me.
Putting that aside, I see the point in the complaint now.
I've pretty much shelved 2015 for other reasons, which is probably why I wasn't bothered by this new behavior before. I could probably deal with it in a 2D/Plan environment, but I do find it annoying that in a 3D environment, the crosshair re-orient to be orthogonal with the view/selection window, and also switch to their 2D color, if different than 3D/Parallel during a window selection.
I just sent Feedback indicating that I don't like crosshairs being visible during window selections.
Contact Us / Feedback --> http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
@cad-pe wrote:Will Autodesk pesonnel make the changes as described by linkboy? I'm getting frustrated with some of the features forced on me. I don't want to unlearn the way I use AutoCAD commands and features and relearn a new set of ways of using AutoCAD.
This is a user to user forum. You'll need to go directly to ADSK if you'd like to actually address an issue with the developers.
True, but I don't mind seeing open letters to Autodesk posted here. It helps to share opinion, and often ideas are shared to mitigate the issue.
Also, depending on the users paid support option, Product Support may be automatically notified for certain topics in certain forums.
Anybody found out if there is a way to get around this yet. Does a system variable exist?
Also, how do I set the "DRAG LINE" color & linetype when displacement is used? I want it black and continuous like other versions. I use a grey background and this orange/peach color is totally lost in the background. Thanks
AFAIK, the dragline/rubberband line color cannot be changed in 2015 as was possible in previous versions, It's another instance where Autodesk did not give proper consideration to how customers use their product.
All you can do is complain via Support and/or Feedback and hope they restore the previous behavior.sometime in the future.
Related --> Link
chreese22 wrote:
Does anyone know if this was fixed in the service pack?
Dragline color? No change as of yet in 2015 or 2016.
Also no change in that regard with any of the SP's or 2016. The link in post #7 above still works to give feedback directly to Autodesk.
I left another comment for 2016.
No change whatsoever in that matter.
-Crossing/window selection crosshair
-Drag line color or linetype
-"Glowing" selection preview instead of just dashed.
2014 was the best!
2014 was the best!
SELECTIONEFFECT = 0 should eliminate the blue glow.
also PRESELECTIONEFFECT
In 2016 for the cursor complaint, CURSORSIZEOFF seems to do the trick.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
